[mapguide-users] Can you help with connection properties for OSGeo.SQLServerSpatial?
Martin Morrison martin.morrison at edsi.com
Fri Nov 13 08:44:42 EST 2009
Are you running SQLExpress or full SQL Server?  If it is Express then the service name needs to SERVERNAME\SQLEXPRESS, if it is Full SQL then just the SERVERNAME...  The datastore field automatically populates after you hit the login button and successfully login.
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JamesDudden
Sent: Friday, November 13, 2009 8:38 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Can you help with connection properties for OSGeo.SQLServerSpatial?
Jackie,
I have tried all different combinations in the Service and Datastore fields
but keep getting the same error when I click test connection:
An exception occurred in FDO component.
RDBMS: No current open database.
Any ideas?
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Can-you-help-with-connection-properties-for-OSGeo-SQLServerSpatial-tp3998955p3999264.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
