[mapguide-users] Resize Box ? hows it work?
Jamo adam.jamison at portbris.com.au
Mon Nov 16 20:07:21 EST 2009
Sort of found a way the resizeBox can work. (it is relevant to the size of
the actual symbol)
the symbol is made to fit 1x1 so when the user inputs size it scale
accordingly.
Would like the text to scale to fit in the ship in the X direction as
well...
so if it was a longer name it would be scaled down in the X and Y so it
fits, it seems to not scale down though?
Also the ghosted text does not work?
<SimpleSymbolDefinition
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="SymbolDefinition-1.1.0.xsd" version="1.1.0">
<Name>Ship</Name>
<Graphics>
<Path>
<ResizeControl>'AddToResizeBox'</ResizeControl>
<Geometry>
M 0,0 L 0.167,1 L 1,1 L 1,-1 L 0.167,-1 Z
</Geometry>
<LineWeight>0.0</LineWeight>
</Path>
<Text>
<ResizeControl>'AdjustToResizeBox'</ResizeControl>
<Content>%NAME%</Content>
<FontName>Arial</FontName>
<Height>0.5</Height>
<Angle>0</Angle>
<PositionX>0.15</PositionX>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<GhostColor>'22055555'</GhostColor>
</Text>
</Graphics>
<ResizeBox>
<SizeX>1</SizeX>
<SizeY>1</SizeY>
<PositionX>0</PositionX>
<PositionY>0</PositionY>
<GrowControl>'GrowInXY'</GrowControl>
</ResizeBox>
<PointUsage>
<Angle>%ROT%</Angle>
</PointUsage>
<ParameterDefinition>
<Parameter>
<Identifier>ROT</Identifier>
<DefaultValue/>
<DisplayName>Rotation</DisplayName>
<Description>Point Symbol Rotation</Description>
<DataType>String</DataType>
</Parameter>
<Parameter>
<Identifier>NAME</Identifier>
<DefaultValue/>
<DisplayName>Vessel Name</DisplayName>
<Description>Vessel Name for Symbol</Description>
</Parameter>
</ParameterDefinition>
</SimpleSymbolDefinition>
View this message in context: http://n2.nabble.com/Resize-Box-hows-it-work-tp4015582p4015844.html
