[mapguide-users] mapguide server crashs even for 5 users
Zac Spitzer zac.spitzer at gmail.com
Wed Nov 18 06:13:16 EST 2009
before i say anything, have a look yourself, tell me what you think the
problem maybe,based on the logs, try and fix it, then ask a question
at the moment, it appears your being very lazy and just falling back on the
list
read the error logs first, then post specific questions, after googling
first
explain why the first error says
"Resource was not found: Library://proptax/layout.WebLayout"
do i need to ask this question? does that exist?
researching first shows your respect for the people
your actually asking on the mailing list.....
On Wed, Nov 18, 2009 at 9:39 PM, sathishpsk9 <sathishpsk9 at gmail.com> wrote:
> hi
> thanks for reply.
> and the error log is :
> # Log Type: Error Log
> # Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
> <2009-08-05T12:32:54>                   Administrator
>  Error: Resource was not found: Library://proptax/layout.WebLayout
>  StackTrace:
>  - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>  - MgOpGetResourceContent.Execute line 120 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpGetResourceContent.cpp
>  - MgServerResourceService.GetResourceContent line 863 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
>  - MgApplicationRepositoryManager.GetResourceContent line 378 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
>  - MgResourceDefinitionManager.GetResource line 320 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>  - MgResourceContentManager.GetDocument line 590 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceContentManager.cpp
>  - MgResourceDefinitionManager.GetDocument line 476 file
> <2009-08-05T13:33:30>
>  Error: Session has expired or is invalid. Please log in again.
>  StackTrace:
>  - MgSiteServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\site\SiteServiceHandler.cpp
>  - MgOpAuthenticate.Execute line 107 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\site\OpAuthenticate.cpp
>  - MgSecurityManager.Authenticate line 224 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\SecurityManager.cpp
>  - MgSessionCache.GetSessionInfo line 175 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\SessionCache.cpp
> <2009-08-11T17:10:50>                   Administrator
> Library://SonshpProp/imcshpproplayout.WebLayout
>  StackTrace:
> Resource was not found: Library://SonshpProp/imcshpproplayout.WebLayout
> <2009-08-11T18:00:28>                   Administrator
>  Error: Resource was not found: Library://thematic/layout.WebLayout
>  StackTrace:
> <2009-08-11T18:00:57>                   Administrator
>  StackTrace:
> <2009-08-11T18:01:12>                   Administrator
>  StackTrace:
> <2009-08-11T18:01:14>                   Administrator
>  StackTrace:
> <2009-08-11T18:01:19>                   Administrator
>  StackTrace:
> <2009-08-11T18:01:28>                   Administrator
>  StackTrace:
> <2009-08-11T18:01:58>                   Administrator
>  StackTrace:
> <2009-08-11T18:02:49>                   Administrator
>  StackTrace:
> <2009-08-11T18:03:30>                   Administrator
>  StackTrace:
> <2009-08-11T18:05:48>                   Administrator
>  StackTrace:
> <2009-08-11T18:05:59>                   Administrator
>  StackTrace:
> <2009-08-11T18:06:59>                   Administrator
>  StackTrace:
> <2009-08-11T18:23:09>                   Administrator
>  StackTrace:
> <2009-08-11T18:26:30>                   Administrator
>  StackTrace:
> <2009-08-11T18:31:57>                   Administrator
>  StackTrace:
> <2009-08-11T18:32:06>
>  Error: Authentication failed.  Please enter a valid username and password.
>  StackTrace:
>  - MgSecurityManager.Authenticate line 190 file
> <2009-08-11T18:38:17>                   Administrator
>  StackTrace:
>  StackTrace:
> <2009-08-11T18:39:36>                   Administrator
>  StackTrace:
> <2009-08-11T18:39:37>
>  StackTrace:
> <2009-08-11T18:41:36>                   Administrator
>  StackTrace:
> <2009-08-11T18:42:12>                   Administrator
>  StackTrace:
> <2009-08-11T18:42:44>                   Administrator
>  StackTrace:
> <2009-08-11T18:44:40>                   Administrator
>  StackTrace:
> <2009-08-11T19:13:55>                   Administrator
>  StackTrace:
> <2009-08-11T20:29:50>                   Administrator
>  Error: Invalid argument(s):
>        The value cannot be less than or equal to zero.
>  StackTrace:
>  - MgRenderingServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>  - MgOpQueryFeatures.Execute line 125 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>  - MgServerRenderingService.QueryFeatures line 652 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>  - MgServerRenderingService.RenderForSelection line 1041 file
> <2009-08-11T20:29:51>                   Administrator
>  StackTrace:
> <2009-08-11T20:29:59>                   Administrator
>  StackTrace:
> <2009-08-11T20:47:09>                   Administrator
>  StackTrace:
> <2009-08-11T21:04:21>                   Administrator
>  StackTrace:
> <2009-08-11T21:07:48>                   Administrator
>  StackTrace:
> <2009-08-11T21:07:52>                   Administrator
>  StackTrace:
> <2009-08-11T21:07:56>                   Administrator
>  StackTrace:
> <2009-08-11T21:08:18>                   Administrator
>  StackTrace:
> <2009-08-11T21:08:27>                   Administrator
>  StackTrace:
> <2009-08-11T21:08:34>                   Administrator
>  StackTrace:
> <2009-08-11T21:08:37>                   Administrator
>  StackTrace:
> <2009-08-12T20:20:16>                   Administrator
> Session:59351c7e-0000-1000-8000-000b6a90df2a_en_7F0000010AFC0AFB0AFA//map.Map
>  StackTrace:
>  - MgOpGetResourceData.Execute line 124 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpGetResourceData.cpp
>  - MgServerResourceService.GetResourceData line 1401 file
>  - MgApplicationRepositoryManager.GetResourceData line 1201 file
> <2009-08-21T13:01:02>                   Administrator
>  StackTrace:
> <2009-08-21T13:01:17>                   Administrator
>  StackTrace:
>  StackTrace:
> <2009-08-21T13:28:12>                   Administrator
>  Error: An exception occurred in DB XML component.
>        Error: XML Indexer:  Parse error in document at line, 1, char 1833.
> Parser message: Empty content not valid for content model:
> '(AreaRule,ExtendedData1)'
>  StackTrace:
>  - MgOpSetResource.Execute line 103 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpSetResource.cpp
>  - MgServerResourceService.SetResource line 713 file
>  - MgRepositoryManager.SetResource line 867 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\RepositoryManager.cpp
>  - MgRepositoryManager.AddResource line 840 file
>  - MgResourceContentManager.AddResource line 183 file
>  - MgResourceContentManager.PutDocument line 624 file
>  - MgResourceDefinitionManager.PutDocument line 554 file
> Error: XML Indexer:  Parse error in document at line, 1, char 1833. Parser
> <2009-08-21T13:28:13>                   Administrator
>  StackTrace:
> <2009-09-03T11:25:29>
>  StackTrace:
> <2009-09-07T16:14:43>
>  StackTrace:
> <2009-09-07T16:14:58>
>  StackTrace:
> <2009-09-07T16:15:00>
>  StackTrace:
> <2009-09-07T16:15:09>
>  StackTrace:
> <2009-09-07T16:15:13>
>  StackTrace:
> <2009-09-07T16:15:14>
>  StackTrace:
> <2009-09-07T16:15:22>
>  StackTrace:
> <2009-09-07T16:15:24>
>  StackTrace:
>  StackTrace:
> <2009-09-07T16:16:24>
>  StackTrace:
> <2009-09-07T16:16:35>
>  StackTrace:
> <2009-09-07T16:16:38>
>  StackTrace:
> <2009-09-07T16:16:42>
>  StackTrace:
> <2009-09-07T16:16:49>
>  StackTrace:
> please help me
> thanks
> sathish
> zspitzer wrote:
> > what does the mapguide error log say?
> > On Wed, Nov 18, 2009 at 8:36 PM, sathishpsk9 <sathishpsk9 at gmail.com>
> > wrote:
> >> hi all
> >> i am using
> >> mapguide server     2.0(mgos)
> >> maestro                1.0.9
> >> .NET framework      2.0
> >> IIS                       5.0
> >> windows xp professional (sp3)
> >> king oracle fdo (3.3)
> >> oracle 10g spatial
> >> p IV (3.2GHz),512mb ram.
> >> when i run the application with 5 users ,after 6 th user mapguide server
> >> crashs.so i tested the application in load runner 9.01 it gave the
> result
> >> as
> >> follows:
> >> Analysis Summary        Period: 10/11/2009 13:03:03 - 10/11/2009
> 13:08:54
> >> Scenario Name:  D:\HP\LoadRunner\scenario\Ghazia_10.lrs
> >> Results in Session:     C:\Documents and Settings\srw\Local
> >> Settings\Temp\res\res.lrr
> >> Duration:       5 minutes and 51 seconds.
> >> Statistics Summary
> >> Maximum Running Vusers:
> >>        5
> >> Total Throughput (bytes):
> >> 28,291,753
> >> Average Throughput (bytes/second):
> >> 80,374
> >> Total Hits:
> >> 3,729
> >> Average Hits per Second:
> >> 10.594    View HTTP Responses Summary
> >> Total Errors:
> >> 24
> >> You can define SLA data using the SLA configuration wizard
> >> You can analyze transaction behavior using the Analyze Transaction
> >> mechanism
> >>  Scenario Behavior Over Time
> >> The SLA status of the following measurements displayed over time. You
> can
> >> select a specific time range for each transaction in order to analyze
> the
> >> time range.
> >> Measurement Name        Time Ranges
> >> Application Under Test Errors   0
> >>        0
> >>        0.6
> >>        0.3
> >>        0
> >>        0.2
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        0
> >>        00:00:00        00:00:15        00:00:35        00:00:55
> >>  00:01:15        00:01:35        00:01:55        00:02:15
> >> 00:02:35        00:02:55        00:03:15        00:03:35        00:03:55
> >>      00:04:15        00:04:35        00:04:55
> >> 00:05:15        00:05:35
> >>  Transaction Summary
> >> Transactions:
> >> Total Passed: 208       Total Failed: 38        Total Stopped: 0
> >>       Average
> >> Response Time
> >> Transaction Name        SLA Status      Minimum Average Maximum Std.
> >> Deviation  90
> >> Percent Pass    Fail    Stop
> >> Action_Transaction
> >> 51.214  60.956  103.222 14.872  95.925  25      19      0
> >> Home
> >> 4.077   4.176   4.324   0.083   4.276   27      0       0
> >> Login
> >> 12.321  21.342  48.682  10.433  41.326  27      17      0
> >> maoInfi
> >> 1.929   2.278   2.818   0.201   2.46    25      2       0
> >> Map
> >> 0.028   0.041   0.161   0.026   0.047   25      0       0
> >> Map1
> >> 0.007   0.012   0.07    0.013   0.012   25      0       0
> >> URL
> >> 0.075   1.936   16.405  5.007   15.645  44      0       0
> >> vuser_end_Transaction
> >> 0       0       0       0       0       5       0       0
> >> vuser_init_Transaction
> >> 0       0       0       0       0       5       0       0
> >> Service Level Agreement Legend:
> >> Pass
> >> Fail
> >> No Data
> >> HTTP Responses  Total   Per second
> >> HTTP_200
> >> 3,260   9.261
> >> HTTP_302
> >> 44      0.125
> >> HTTP_401
> >> 1       0.003
> >> HTTP_403
> >> 309     0.878
> >> HTTP_404
> >> 115     0.327
> >> plz help me...
> >> sathish
> >> View this message in context:
> http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4024330.html
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zac Spitzer
> > Solution Architect / Director
> > Ennoble Consultancy Australia
> > http://www.ennoble.com.au
> > http://zacster.blogspot.com
> > +61 405 847 168
> http://n2.nabble.com/mapguide-server-crashs-even-for-5-users-tp4024330p4024594.html
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091118/6455664b/attachment.html
