[mapguide-users] MGOS 1.2.0 Filter On Joined Field
Dave Wilson dave.wilson at autodesk.com
Mon Nov 23 15:44:17 EST 2009
This looks like a new defect. I just tried this and got an exception:
<2009-11-23T13:08:52> 	2028	Ajax Viewer	144.111.170.113	Administrator
 Error: Failed to stylize layer: LayerDefinition76
        An exception occurred in FDO component.
        Failed to execute query.
 StackTrace:
  - MgMappingUtil.StylizeLayers() line 791 file d:\build\testarossa_nightly\build_37.1\ent\os\server\src\services\mapping\MappingUtil.cpp
It appears to be a problem using the secondary columns in the filter.
In fact it's been broken for a while, possibly since FDO G052 or earlier.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Monday, November 23, 2009 9:29 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MGOS 1.2.0 Filter On Joined Field
Hi Bruno,
We have officially released MapGuide Open Source 2.1.0.  Is the same problem present in the release build http://mapguide.osgeo.org/download/releases/2.1.0?
Thanks,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: November 23, 2009 7:53 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MGOS 1.2.0 Filter On Joined Field
I've just tried a filter on 2 joined tables
  primary SDF Secondary Oracle
  primary SDF Secondary Access
Both failed, does not show any record as soon as a set a filter on a
secondary table field.
I've tested against mapguide 2.1 Beta and Mapguide Enterprise 2010
Maybe we should reopen ticket 292
http://trac.osgeo.org/mapguide/ticket/292
Bruno
View this message in context: http://n2.nabble.com/MGOS-1-2-0-Filter-On-Joined-Field-tp1812320p4051510.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
