[mapguide-users] RE: MGOS 2.1 Load Pakage not working
Trevor Wekel trevor_wekel at otxsystems.com
Fri Oct 9 12:31:36 EDT 2009
Hi Fraser,
Are there any exceptions logged in the MapGuide Server error log?  If the Site Administrator is sending request to the server, you should also see entries in the MapGuide Server access  log.
Do the port definitions in webconfig.ini and serverconfig.ini match?  I suspect this is not the problem but it is worth a quick check just to make sure.
Also, did you try rebooting the machine after installation?  I have seen occasional strange behaviour with IIS not picking up system path changes until after a reboot.  If you can log into the Site Administrator, this is likely not the problem.
Thanks,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser Burgess
Sent: October 9, 2009 9:25 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: MGOS 2.1 Load Pakage not working
Good suggestion
Tried it and everything looks like it is pointing to appropriate MGOS directories.
Just as a note.  This is a fresh install of Win2003 Server - MGOS was the first and only thing to be installed (outside of adding IIS).
Cheers,
Fraser
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Friday, October 09, 2009 11:11 AM
Maybe there are issues with your PHP installation? Try a phpinfo page in your root MapGuide folder and see if the pathing and everything is correct. Maybe you have another php instance that is causing a conflict?
Dave
Sent: Friday, October 09, 2009 9:06 AM
Thanks Dave,
Still no luck
Fraser
Sent: Thursday, October 08, 2009 1:07 PM
Subject: [mapguide-users] RE: MGOS 2.1 Load Pakage not working
Increase the max file upload setting in your php.ini to something bigger than your largest anticipated package. The default is 2M.
Dave
Sent: Thursday, October 08, 2009 9:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 2.1 Load Pakage not working
I've installed MGOS 2.1 (.Net / IIS Configuration) and have logged into the site administrator.  The list of packages is populated as it should be and the correct package name has been selected in the list.  I select "Load Package" and the page scrolls to the top and nothing happens.  I've been clicking around in the site administrator and have noticed some other links that don't seem to work.
I checked the configure services and it appears that all the links are pointing to the right spot (I used all the default directories in the install).
Any ideas?
Fraser
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091009/55d166b7/attachment.html
