[mapguide-users] Passing username and password into url with fusion
GordonL gordon.luckett at arrowgeomatics.com
Wed Oct 21 18:37:25 EDT 2009
You can fix it with that fix that was listed on an earlier post:
In ApplicationDefinition.js, the method getAppDef(xhr) needs to be changed
to be like this:
    getAppDef: function(xhr){
      if (xhr && typeof(xhr) == "object" && xhr.responseText) {
        this.sessionId = xhr.responseText;
        Fusion.sessionId = this.sessionId;
      var r = new
Fusion.Lib.MGRequest.MGGetResourceContent(this.applicationDefinition);
      r.parameters.session = this.sessionId;
      r.parameters.format = 'application/json';
      this.oBroker.dispatchRequest(r,
              OpenLayers.Function.bind(this.getAppDefCB, this));
regards
gordon
ary_s wrote:
> the example works for IE and Chrome but my FF still ask username and
> password.
> thanks
> Andy Morsell wrote:
>> No, Fusion does not support that.  See this issue on the Fusion Trac:
>> http://trac.osgeo.org/fusion/ticket/105
>> You can, however, pass a valid SESSION at the URL to bypass the login
>> prompt.  See the attached example.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> 47° 46' N 116° 49' W
>> www.SpatialGIS.com
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser
>> Burgess
>> Sent: Tuesday, October 20, 2009 12:06 PM
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] Passing username and password into url with
>> fusion
>> Is there a trick to passing username and password into a URL with Fusion:
>> A URL such as
>> http://mywebsite.com/mapguide2010/fusion/templates/mapguide/TMOslate/index.h
>> tml?ApplicationDefinition=Library%3a%2f%2fTMO%2fLayouts%2fTMO%20Map.Applicat
>> ionDefinition
>> <http://mywebsite.com/mapguide2010/fusion/templates/mapguide/TMOslate/index.
>> html?ApplicationDefinition=Library%3a%2f%2fTMO%2fLayouts%2fTMO%20Map.Applica
>> tionDefinition&LOCALE=en&USERNAME=Anonymous&PASSWORD=>
>> still brings up the log in prompt
>> Fraser
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Passing-username-and-password-into-url-with-fusion-tp3860654p3869011.html
