[mapguide-users] Coordinate system transformation
mighty_duck msiljegovic at gmail.com
Tue Sep 1 05:41:07 EDT 2009
thanks for answer Kenneth
By the way, about labeling that we were discussing....I succeeded to
implement some prototype labeling using your advices.
thanks again
regards
Kenneth Skovhede, GEOGRAF A/S wrote:
> For some reason, your FeatureSource does not have a spatial context.
> I don't know how to fix this with Oracle, but for other providers, it is
> not unusual that they lack spatial context.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mighty_duck skrev:
>> Hello,
>> Im having next problems during performing coordinate system
>> transformation:
>> Here is the code
>>              MgSpatialContextReader context;
>>              context =
>> featureService1.GetSpatialContexts(layerFeatureResources1, true);
>>              context.ReadNext();
>>              string coordSys = context.GetCoordinateSystemWkt();
>>              MgCoordinateSystemFactory coordSysFac = new
>> MgCoordinateSystemFactory();
>>              MgCoordinateSystem cs;
>>              cs = coordSysFac.Create(coordSys);
>>              string mapCoordSys = map1.GetMapSRS();
>>              MgCoordinateSystem csNew;
>>              csNew = coordSysFac.Create(mapCoordSys);
>>              MgCoordinateSystemTransform coordSysTransf;
>>              coordSysTransf = coordSysFac.GetTransform(cs, csNew);
>>              Problem starts at context object (second line) where I
>> recieve
>> exception "index is out of the range".
>> Does anyone know what can be a problem? Im using Oracle as data source!!!
>> thanks in advance
>> regards
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Coordinate-system-transformation-tp3559335p3559403.html
