[mapguide-users] Navigator(Zoom Slider), Virtual Earth Zoom, open layers in Basic web layout
Fraser Burgess fburgess at lakelandenergy.com
Thu Sep 10 11:19:03 EDT 2009
I have a few questions and was hoping to get some suggestions from the
list.  I'm running the MapGuide Enterprise 2010 :
1.       How can I move the Navigator(zoom slider) control in the fusion
slate viewer?  Currently it is fixed at the top right and I would like
to move it to the top left.
2.       Using the usual  'addGoogleStuff' code I've added with Virtual
Earth base layers along with Google base layers in the Slate fusion
template.   I am unable to zoom in past about 1:5000 when I use the
Virtual Earth base layers.  I believe there should still be 2 more zoom
levels I should be able to achieve with virtual earth base layers.  The
numZoomLevels option is set to 30 which I think is far more than what is
offered in MSVE.  Using Google Earth as my base I can zoom right in.
Any idea how I can zoom in closer to the MSVE base layers
3.       So I've been somewhat successful at adding the 'addgooglestuff'
code to a flexible fusion layout.  Is it possible to do the same thing
in a Basic Ajax Layout?  If so what file should I be adding code to use
the google / MSVE as a base in my Basic Web Layout.  Is t here any
sample pages out there that have done this?
Thanks
Fraser
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090910/7a2148ba/attachment.html
