[mapguide-users] RE: parent.parent.parent.mapFrame - AJAX vs FUSION
Chris Claydon chris.claydon at autodesk.com
Wed Sep 16 16:29:48 EDT 2009
'parent' takes you to the frame that is the parent of the one you're running the script in. The GetParent() method as defined below looks for 'Fusion' to be defined either in the direct parent or the parent of that frame. If you're launching in a new window, you'll never get to a parent that has Fusion defined. I think you need to use 'opener' instead...
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser Burgess
Sent: Wednesday, September 16, 2009 2:04 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: parent.parent.parent.mapFrame - AJAX vs FUSION
So GetParent() worked when things were called with "parent.parent.parent.mapFrame"; however, what if I have something in AJAX like this:
function OnPageLoad()
    parent.ZoomToView(<%= GetRequestParameters()["X"] %>, <%= GetRequestParameters()["Y"] %>, <%= GetRequestParameters()["Scale"] %>, true);
I then modify by adding your code below and then try:
function GetParent()
            if (parent.Fusion) {
                return parent;
            } else if (parent.parent.Fusion) {
                return parent.parent;
    GetParent().ZoomToView(<%= GetRequestParameters()["X"] %>, <%= GetRequestParameters()["Y"] %>, <%= GetRequestParameters()["Scale"] %>, true);
This code is using the sample gotopoint.aspx file.  When I select the link that activates this gotopoint, the URL contains the X Y and scale http://172.16.186.38/mapguide2010/UtilityMap/gotopoint.aspx?X=632593.974151717&Y=4989398.03115329&Scale=25000 which should be passed into this onPageLoad() function.  However it appears that nothing is firing for OnPageLoad - so when I click the link nothing happens, no error message or anything.
Can anyone help with this problem?  Also, can anyone point me to something that would help explain this parent.parent. syntax?  I'm not really certain why at one point we would use parent.function() vs parent.parent.parent.function() etc.
Thanks again
Fraser
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Wednesday, September 16, 2009 9:02 AM
Subject: [mapguide-users] RE: parent.parent.parent.mapFrame - AJAX vs FUSION
If you want to add the reference to your fusion index page, add the following to your aspx (task pane) page
                return parent;
Then you can call functions in the same way as before but substitute
GetParent().DigitizePoint(OnPointDigitized);
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com<http://www.mcmtrans.com>
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Claydon
Sent: Tuesday, September 15, 2009 4:43 PM
I think you should be able to reference the MapGuideViewerAPI.js script from your aspx page, and then just call DigitizePoint directly without any window.top or parent references.
It should also be possible to add a reference to MapGuideViewerAPI.js to the index.html file in the Fusion template you're using, and reference it using window.top...
It's been a while since I've played around with this stuff, so someone else may be able to provide specifics...
Sent: Tuesday, September 15, 2009 1:40 PM
Subject: [mapguide-users] parent.parent.parent.mapFrame - AJAX vs FUSION
Hi List,
I'm making steady progress with my project and learning many things about MapGuide along the way thanks largely to the help from those on this list - many thanks to those who have helped so far
>From what I can tell parent.parent.parent.mapFrame is how the map frame is referenced from the task pane in the AJAX viewer.  I have been reading posts about how this is referenced in Fusion and it seems the MapGuideViewerAPI.js file has a bit of info.  Unfortunately I'm having a bit if trouble putting the pieces together and was hoping that someone here may steer me in the right direction.
In both AJAX and FUSION I'm working from the taskpane and using the markup scripts that are part of the AJAX demo's and tutorials.
I assume I need to substitute either 'Fusion' or 'window.top.Fusion' somehow for 'parent.parent.parent.mapFrame.DigitizePoint(OnPointDigitized);'. in my script however I have yet to do this in such a way that it works.  I keep getting 'Object doesn't support this property or method'.
So for example in my editmarkup.aspx code for example, I have the following function which should be activated when I click the digitize point button
            function AddPoint()
                  SetDigitizeInfo(EDIT_POINT_HELP);
In Fusion this code gives an error 'parent.parent,parent.mapFrame' is null or not an object
I see that in MapGuideViewerAPI.js
function DigitizePoint(handler) {
    if (handler) {
      var Fusion = window.top.Fusion;
      var mapWidget = Fusion.getWidgetById(mapWidgetId);
      var digitizer = new Fusion.Tool.Canvas.Point(mapWidget);
      digitizer.mouseUp = PointHandlers.prototype.mouseUp;
      Object.inheritFrom(digitizer, Fusion.Tool.Canvas.prototype, []);
      digitizer.initializeCanvas();
      var activeWidget = mapWidget.buttonSet.activeButton;
      mapWidget.buttonSet.setActiveButton(null);
      digitizer.handler = function() {
          handler.apply(null, arguments);
          activeWidget.setActive(true);
      digitizer.activateCanvas();
      //add a listener to update the position of the features
      mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED,
        function(){
          digitizer.updatePx();
          digitizer.clearContext();
          digitizer.draw(digitizer.context);
Thanks
Fraser
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090916/b03fa6f2/attachment.html
