[mapguide-users] trouble connecting mapguide maestro postgis
Remco Houtkamp r.houtkamp at burohoutkamp.nl
Fri Sep 18 04:46:27 EDT 2009
You guys respond faster than I can check it! Great list!
But... for some reason Test connection does not work anymore only
difference is a restart of my laptop.
Logfile tells me:
<2009-09-18T10:40:23>                3508                      127.0.0.1
Administrator
 Error: An exception occurred in FDO component.
        Unable to load the FDO Provider: (null)
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHan
dler.cpp
  - MgOpTestFeatureSourceConnection.Execute line 100 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSour
ceConnection.cpp
  - MgFdoConnectionManager.Open line 262 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManage
r.cpp
Maestro gives the following error:
De externe server heeft een fout geretourneerd: (559) MgFdoException.:
Since installing/registering libpq.dll worked yesterday, I've redone
that step... but no cigar... I'm trying to learn GIS for some months
now, but the assumingly last obstacles are very hard to pass....
Met vriendelijk groet,
Remco Houtkamp
BURO HOUTKAMP
|T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl
<mailto:r.houtkamp at burohoutkamp.nl>  |P:  Kweldergras 21, 1441 WP,
Purmerend |
Van: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Kenneth Skovhede,
GEOGRAF A/S
Verzonden: donderdag 17 september 2009 14:22
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro
postgis
ieshims.dll and ieframe.dll can be ignored.
There should be no harm in copying the files, but it's not required.
Now that you get that error, it is likely that the error.log contains
extra information:
2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
The MgConnectionFailedException usually means that the MapGuide service
has stopped.
Regards,. Kenneth Skovhede, GEOGRAF A/S
Remco Houtkamp skrev:
Been strugling along. Depend.exe told libpq.dll could not be opened. I
googled for it, followed instructions and installed it. Now when I press
test connections, it will not give me errors...seems like progress!
I saved the data connection and tried to connect a layer. Maestro tells
me:
Failed to read schema from data source.
The operation gave the error message: De externe server heeft een fout
geretourneerd (Dutch for the external server returned an error): (559)
MgConnectionFailedException.: Cannot establish connection.
Depend.exe also says it cannot open ieshims.dll so I just copied it (is
that ok) to the FDO folder.
Now it only says Warning: At least one module has an unresolved import
due to a missing export function in a delay-load dependent module.
It also shows a hourglass and some kind of red grid on an icon for the
file ieframe.dll
-----Oorspronkelijk bericht-----
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: woensdag 16 september 2009 16:08
postgis
try running depends.exe (google it) on the  postgis fdo provider dll
sounds like the required postgres dll's are being found
z
On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> <mailto:r.houtkamp at burohoutkamp.nl>  wrote:
	Hi all, this is my first post, still a newbie.
	I think I managed to import data from openstreetmap.org to
postgis. But now
	I cannot connect. I guess things are working since I can connect
from a
	program called Udig.
	In mapguide maestro I go through the following steps:
	Create a new resource>data connection
	OSGEO FDO Provider for Postgis
	Database: osm  (is visible in Udig)
	server: I tried localhost http://localhost/ <http://localhost/>
127.0.0.1 http:// <http://>  127.0.0.1/
	Port: 5432
	Tried all three credentials but think it must be Specified
Credentials with
	user postgres and my secret password ;)
	Press test connection and then the following error appears:
MgFdoException.: An
	exception occurred in FDO component. Unable to load the FDO
Provider: Kan
	opgegeven module niet vinden. (some of this is Dutch...)
	My setup contains postgresql 8.4 and postgis 1.4.
	Can anybody tell me where I'm going wrong... struggling for days
and days... and
	days...
	mapguide-users mailing list
	mapguide-users at lists.osgeo.org
<mailto:mapguide-users at lists.osgeo.org>
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
<http://lists.osgeo.org/mailman/listinfo/mapguide-users>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090918/4693281a/attachment.html
