[mapguide-users] Tile base cache (how to tile the map)
Denny S denny_sutanto1 at yahoo.com
Wed Sep 23 09:08:03 EDT 2009
My folder is empty
C:\Program
Files\Autodesk\MapGuideEnterprise2009\Server\Repositories\TileCache\Samples_Sheboygan_MapsTiled_Sheboygan\S3\Base
Layer Group\R0\C0
I think it's because i don't have base layer group, is it ?
Based on this link by jason birch
http://www.jasonbirch.com/nodes/category/mapguide/
I can see "Base Layer Group" folder under [...] Finite display scales, but i
cannot see one in my PC.
And also under Setup a tile build, i cannot see "Base Layer Group".
What should i do ? what is base layer group is ?
Thanks
zspitzer wrote:
> under the mapguide server directory\repositories\tilecache
> z
> On Wed, Sep 23, 2009 at 10:52 PM, Denny S <denny_sutanto1 at yahoo.com>
> wrote:
>> Thanks zspitzer,
>> Now i can test the mgcooker.
>> I use Sheboygan Map, then i click "Base layer groups" tab, then i clicked
>> the MGCooker icon,
>> I specified the user and password, then clicked "build tiles now". It ran
>> very fast, seems like nothing happed. I cannot find the tiles that just
>> being built. Where is it ?
>> THanks
>> zspitzer wrote:
>>> scroll down, try the preview release
>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi
>>> you can run cooker
>>> On Wed, Sep 23, 2009 at 10:32 PM, Denny S <denny_sutanto1 at yahoo.com>
>>> wrote:
>>>> Wow very fast reply
>>>> I use Version 1.0.9.15910
>>>> I downloaded it from the link you passed me
>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>> Inside that page i click Installer (recommended) under windows current
>>>> release
>>>> Here is the url that i downloaded
>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%201.0.9.msi
>>>> Which preview should i use ?
>>>> Thanks
>>>> zspitzer wrote:
>>>>> are you running 1.0.9 or the preview version?
>>>>> i think you need the preview version?
>>>>> On Wed, Sep 23, 2009 at 9:44 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>>> wrote:
>>>>>> Hi zspitzer,
>>>>>> I'm very new to mapguide, i have downloaded the mapguide maestro,
>>>>>> then
>>>>>> when
>>>>>> i started the maestro, it asked me to login to my local server,i
>>>>>> successfully connected.
>>>>>> I have "Sheboygan Public" folder, this folder i created base on the
>>>>>> step
>>>>>> by
>>>>>> step exercise provided by Map Guide Studio 2009.
>>>>>> I browse to my Maps folder under Sheboygan Public, i clicked the map
>>>>>> there,
>>>>>> but i cannot see the MGCooker icon there. I have only 2 tabs inside
>>>>>> layers
>>>>>> section, which are "Layers by group" , "Layers by drawing order".
>>>>>> Maybe
>>>>>> my
>>>>>> map is not a base layer group ?
>>>>>> How do i create one ? What should i do to test the mgcooker. I want
>>>>>> to
>>>>>> create map tile same as google map. For example : 0_0.gif, 0_1.gif,
>>>>>> 1_0.gif,
>>>>>> etc
>>>>>> Thanks
>>>>>> zspitzer wrote:
>>>>>>> the tile cache is created on demand simply by viewing a tiled map
>>>>>>> a tiled map is a map which has base layer groups
>>>>>>> changing anything connected to the map, ie layers, will flush the
>>>>>>> tile
>>>>>>> cache
>>>>>>> On Fri, Jun 19, 2009 at 10:49 AM, CroNicoRn<ah_jid at yahoo.com> wrote:
>>>>>>>> d screen shot where d tiles make..
>>>>>>>> http://n2.nabble.com/file/n3116839/mapguide_tiles.jpg
>>>>>>>> http://www.myguidepages.com
>>>>>>>>  http://n2.nabble.com/file/u115131/ajid.jpg
>>>>>>>> View this message in context:
>>>>>>>> http://n2.nabble.com/Tile-base-cache-%28how-to-tile-the-map%29-tp3066013p3116839.html
>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>> Zac Spitzer -
>>>>>>> http://zacster.blogspot.com
>>>>>>> +61 405 847 168
>>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699041.html
>>>>> Zac Spitzer -
>>>>> +61 405 847 168
>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699254.html
>>> Zac Spitzer -
>>> +61 405 847 168
>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699395.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699495.html
