[mapguide-users] JSP and PHP and fusion
Paul Spencer pagameba at gmail.com
Thu Sep 24 08:31:57 EDT 2009
Fusion is still unfortunately buggy in some specific areas, your
mileage will vary depending on how you use it (we use it extensively
without problems - or at least we fix the problems as we run into
them).  Fusion is designed to support alternate back ends (jsp,
php, .net) but only the PHP version exists at this time so you do have
to have both PHP and JSP versions of mapguide web tier installed -
there have been reports of using fusion/php and developing task panes
in .NET and perhaps JSP successfully.
Cheers
Paul
On 2009-09-24, at 3:33 AM, oshan wrote:
> Hey Guys
> So I'm just trying to get started with mapguide. I want to know if
> there is
> any Documentation specific to using the JSP API. The developers
> guide seams
> focus on PHP.
> Also what do you guys think is better to use PHP or JSP?
> The reason why I am leaning towards JSP is because it is essentially
> Java
> programming and I am familiar with Java (altho I have never used JSP)
> where
> as I have only slight knowledge with PHP and I also have the
> perception that
> since its Java with the whole OO stuff, it'll prolly be easy to
> program in!?
> Since I couldn't find any JSP documentation I looked at the sample
> JSP ajax
> viewer code and it looks a bit scary: there is a whole lot of code!
> I would
> like to see more of a step by step approach with JSP.
> Also I looked into this fusion thing but it seams a bit buggy. I
> don't know
> if any of you have experienced that. Like I would specify some
> widgets but
> they would never show up. I heard that fusion use PHP for it server
> stuff.
> Does this mean I have to configure mapguide to use PHP instead of
> JSP. when
> I install it I set it up to use JSP!
> thanks
> View this message in context: http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3704607.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
