[mapguide-users] RE: Event that captures mouse action
Martin Morrison martin.morrison at edsi.com
Mon Apr 5 09:06:12 EDT 2010
You can turn off the context menu in Studio, simply uncheck the box.  The only way to have a right click to select is to have them click the toolbar to select, so remove the select button.  Both of these are on the web layout.  You can also make all of the layers non-selectable (this is on the map).  AFAIK, to disable the mouse wheel you will need to find the code that controls the wheel function and remove it.
But WHY???  (just curious)
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of SriRam007
Sent: Monday, April 05, 2010 8:54 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Event that captures mouse action
Can i disable mouse right click, left click and mouse wheel functions for a
Map
I want these functions should not work for the map
like
. On right click context menu should not come
. On left click features shoule not select
. On mouse wheel move the zoom in and zoom out function should not work
Is there any way to do this
thanks
View this message in context: http://n2.nabble.com/Event-that-captures-mouse-action-tp3939442p4853354.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
