[mapguide-users] Problem with Find Address
padmini godavarthi godavarthi.padmini at gmail.com
Thu Apr 8 01:42:11 EDT 2010
iam just trying for the find address functionality in phpviewersample.
while running it i got this warnings and nothing is displayed..
Warning: Call-time pass-by-reference has been deprecated; If you would like
to pass it by reference, modify the declaration of xml_set_object(). If you
would like to enable call-time pass-by-reference, you can set
allow_call_time_pass_reference to true in your INI file in C:\Program
Files\OSGeo\MapGuide\Web\www\phpviewersample\findaddress\kd_xmlrpc.php on
line 83
to pass it by reference, modify the declaration of array_unshift(). If you
line 136
to pass it by reference, modify the declaration of [runtime function
name](). If you would like to enable call-time pass-by-reference, you can
set allow_call_time_pass_reference to true in your INI file in C:\Program
line 159
to pass it by reference, modify the declaration of XML_unserialize(). If you
line 168
line 190
line 205
line 247
line 251
line 270
line 275
to pass it by reference, modify the declaration of XMLRPC_adjustValue(). If
you would like to enable call-time pass-by-reference, you can set
line 319
line 395
line 401
to pass it by reference, modify the declaration of XML_serialize(). If you
line 412
Warning: fsockopen() [function.fsockopen]: unable to connect to
rpc.geocoder.us:80 (A connection attempt failed because the connected party
did not properly respond after a period of time, or established connection
failed because connected host has failed to respond. ) in C:\Program
line 357
Warning: array_key_exists() [function.array-key-exists]: The second argument
should be either an array or an object in C:\Program
Files\OSGeo\MapGuide\Web\www\phpviewersample\findaddress\findaddress.php on
line 84
 Address not found: 1716 ILLINOIS AVE , Sheboygan, WI
Geocoding Provided by: geocoder.us.
Locative Tecnologies offers the free geocoder.us web service for non
commercial purposes. If you wish to use this geocoding web service in an
production application you must sign up for a commercial license. Click the
link above for more information.
Please tell me how to use this function?
View this message in context: http://n2.nabble.com/Problem-with-Find-Address-tp4869309p4869309.html
