[mapguide-users] Problem with Find Address
Zac Spitzer zac.spitzer at gmail.com
Thu Apr 8 01:46:13 EDT 2010
did you try setting
allow_call_time_pass_reference to true in your INI file ?
On 8 April 2010 15:42, padmini godavarthi <godavarthi.padmini at gmail.com> wrote:
> Hi,
> iam just trying for the find address functionality in phpviewersample.
> while running it i got this warnings and nothing is displayed..
> Warning: Call-time pass-by-reference has been deprecated; If you would like
> to pass it by reference, modify the declaration of xml_set_object(). If you
> would like to enable call-time pass-by-reference, you can set
> allow_call_time_pass_reference to true in your INI file in C:\Program
> Files\OSGeo\MapGuide\Web\www\phpviewersample\findaddress\kd_xmlrpc.php on
> line 83
> to pass it by reference, modify the declaration of array_unshift(). If you
> line 136
> to pass it by reference, modify the declaration of [runtime function
> name](). If you would like to enable call-time pass-by-reference, you can
> set allow_call_time_pass_reference to true in your INI file in C:\Program
> line 159
> to pass it by reference, modify the declaration of XML_unserialize(). If you
> line 168
> line 190
> line 205
> line 247
> line 251
> line 270
> line 275
> to pass it by reference, modify the declaration of XMLRPC_adjustValue(). If
> you would like to enable call-time pass-by-reference, you can set
> line 319
> line 395
> line 401
> to pass it by reference, modify the declaration of XML_serialize(). If you
> line 412
> Warning: fsockopen() [function.fsockopen]: unable to connect to
> rpc.geocoder.us:80 (A connection attempt failed because the connected party
> did not properly respond after a period of time, or established connection
> failed because connected host has failed to respond. ) in C:\Program
> line 357
> Warning: array_key_exists() [function.array-key-exists]: The second argument
> should be either an array or an object in C:\Program
> Files\OSGeo\MapGuide\Web\www\phpviewersample\findaddress\findaddress.php on
> line 84
>  Address not found: 1716 ILLINOIS AVE , Sheboygan, WI
> Geocoding Provided by: geocoder.us.
> Locative Tecnologies offers the free geocoder.us web service for non
> commercial purposes. If you wish to use this geocoding web service in an
> production application you must sign up for a commercial license. Click the
> link above for more information.
> Please tell me how to use this function?
> View this message in context: http://n2.nabble.com/Problem-with-Find-Address-tp4869309p4869309.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
