[mapguide-users] Edit WebLayout Problem
SriRam007 binod_tripathy at yahoo.co.in
Thu Apr 8 02:48:07 EDT 2010
Hi everyone,
I m trying to edit the WebLayout using C#.net and i m using ajax viewer with
basic layout (SheboyganAsp)
here is my code for making tool bar invisible
    public String MapName = "Sheboygan";
    public String WebLayoutName =
"Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
   protected void btn_Click(object sender, EventArgs e)
        Utility.InitializeWebTier(Request);
        MgUserInformation userInfo = new
MgUserInformation(Session["ID"].ToString());
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
        MgMap map = new MgMap();
        map.Open(resourceService, MapName);
        MgResourceIdentifier WebLayoutId = new
MgResourceIdentifier(WebLayoutName);
        MgByteReader byteReader =
resourceService.GetResourceContent(WebLayoutId);
        XmlDocument doc = new XmlDocument();
        string xmlLayoutDef = byteReader.ToString();
        doc.LoadXml(xmlLayoutDef);
        string MapDefinitionStr = ReplaceTextNodeValue(xmlLayoutDef,
"false");//Here i m finding the tool bar node and then visible node and
replacing the value true to false  //
        resourceService.SetResource(WebLayoutId, new
MgByteReader(MapDefinitionStr, "text/xml"), null);//Error showing
"Unauthorised Acces"
where is the problem can any one help me
thanks
View this message in context: http://n2.nabble.com/Edit-WebLayout-Problem-tp4869470p4869470.html
