[mapguide-users] Re: Edit WebLayout Problem
Jackie Ng jumpinjackie at gmail.com
Thu Apr 8 02:51:48 EDT 2010
Assuming you're using a session based off of the Anonymous login, this is
expected behaviour because the Anonymous login does not have write access to
the main site repository.
If you want to do this kind of stuff, write your changes to the session
repository instead.
- Jackie
View this message in context: http://n2.nabble.com/Edit-WebLayout-Problem-tp4869470p4869482.html
