[mapguide-users] Re: Edit WebLayout Problem
Jackie Ng jumpinjackie at gmail.com
Thu Apr 8 03:57:57 EDT 2010
If you modify the weblayout document, you need to reload the entire viewer
using the resource id of this modified weblayout to see the changes.
You cannot modify the visibility of AJAX viewer UI elements once it has been
loaded.
- Jackie
View this message in context: http://n2.nabble.com/Edit-WebLayout-Problem-tp4869470p4869686.html
