[mapguide-users] Security restrictions on layers functionality
Jason Birch jason at jasonbirch.com
Fri Apr 9 21:31:51 EDT 2010
No, the only workaround is to programatically generate the map at run
time based on the user's permissions. Not an especially easy task,
even if you're using MaestroAPI.
This is a longstanding issue. Someone's putting together a Google
Summer of Code proposal to work on this; if accepted hopefully we'll
see it for 2.3.
On 2010-04-09, antonio.net <antonio at solvemx.com> wrote:
> I've noticed that if the map is already loaded, and you deny permission to a
> layer to the logged in user, the layer will disappear! Marvelous!
> But then when that same user tries to login using the same Map the
> "Permission denied to resource" message will appear.
> Is there a workaround for this?
> http://n2.nabble.com/Security-restrictions-on-layers-functionality-tp4249130p4880352.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
