[mapguide-users] Re: Edit WebLayout Problem
Zac Spitzer zac.spitzer at gmail.com
Mon Apr 12 02:24:46 EDT 2010
after you modify the weblayout, can you confirm via a getResourceContent
call that the change has actually been made to the xml?
are you sure that the same sessionID is being used after the reload?
On 12 April 2010 16:20, SriRam007 <binod_tripathy at yahoo.co.in> wrote:
> even if i press the reload i don't see the changes
> Where i went wrong
> please
> thanks
> View this message in context: http://n2.nabble.com/Edit-WebLayout-Problem-tp4869470p4888620.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
