R: [mapguide-users] Re: mapguide-users Digest, Vol 40, Issue 14
Bracco Stefano Stefano.Bracco at eurac.edu
Sun Apr 18 02:05:58 EDT 2010
Hi Adam,
not I didn't get undefined error.
In this case I think is more a problem of compiler, I'm pretty sure all that functions were compiled in my environment.
Be careful, if you are using CentOs and/or RedHat, in release 5 you could have problems with linker which is unable to link the libs already compiled.
To solve this, just upgrade to the last release of the linker and compiler.
Stefano
-----Messaggio originale-----
Da: mapguide-users-bounces at lists.osgeo.org per conto di Balogh Ádám
Inviato: ven 16/04/2010 10.35
A: MapGuide Users Mail List
Oggetto: [mapguide-users] Re: mapguide-users Digest, Vol 40, Issue 14
Dear Stefano,
Did you also get so many "undefined reference" errors?
Adam
/usr/local/src/MgDev-2.2.4731/Oem/DWFTK7.1/develop/global/src/dwfemap/.libs/libdwfemap:
undefined reference to `non-virtual thunk to
DWFToolkit::DWFGlobalSection::~DWFGlobalSection()'
`DWFToolkit::DWFXMLSerializable::setDefaultNamespace(DWFCore::DWFString
const&)'
DWFToolkit::DWFSection::buildGraphicResource(char const**,
DWFToolkit::DWFPackageReader*)'
`DWFToolkit::DWFPropertyContainer::getReferencedPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
std::allocator<DWFToolkit::DWFPropertyContainer*> >&)'
DWFToolkit::DWFSection::~DWFSection()'
DWFToolkit::DWFSection::buildImageResource(char const**,
`DWFToolkit::DWFInterface::serializeXML(DWFToolkit::DWFXMLSerializer&,
unsigned int)'
DWFToolkit::DWFGlobalSection::provideProperty(DWFToolkit::DWFProperty*)'
DWFToolkit::DWFGlobalSection::provideVersion(double)'
/usr/local/src/MgDev-2.2.4731/Common/Renderers/.libs/libMgRenderers.so:
undefined reference to `WT_PNG_Group4_Image::WT_PNG_Group4_Image(unsigned
short, unsigned short, WT_PNG_Group4_Image::WT_PNG_Group4_Image_Format,
long, WT_Color_Map const*, long, unsigned char*, WT_Logical_Point const&,
WT_Logical_Point const&, char)'
DWFToolkit::DWFSection::buildResource(char const**,
DWFToolkit::DWFGlobalSection::provideFontResource(DWFToolkit::DWFFontResource*)'
`DWFToolkit::DWFSection::serializeXML(DWFToolkit::DWFXMLSerializer&,
unsigned int)'
`DWFToolkit::DWFGlobalSection::serializeXML(DWFToolkit::DWFXMLSerializer&,
unsigned int)'
/usr/local/src/MgDev-2.2.4731/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so:
undefined reference to `WT_Point_Set::WT_Point_Set(int, WT_Logical_Point
const*, char)'
`DWFToolkit::DWFPropertyContainer::getOwnedPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
`DWFToolkit::DWFPropertyContainer::removeOwnedPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
std::allocator<DWFToolkit::DWFPropertyContainer*> >&, bool)'
`DWFToolkit::DWFXMLSerializable::addNamespace(DWFCore::DWFString const&,
DWFCore::DWFString const&)'
`DWFToolkit::DWFXMLSerializer::startElement(DWFCore::DWFString const&,
unsigned int)'
`DWFToolkit::DWFXMLSerializable::DWFXMLSerializable(DWFCore::DWFString
const&)'
DWFToolkit::DWFSection::buildFontResource(char const**,
`DWFToolkit::DWFPropertyContainer::removeAllPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
`WT_Text_Background::WT_Text_Background(WT_Text_Background::WT_Background,
long)'
DWFToolkit::DWFGlobalSection::provideGraphicResource(DWFToolkit::DWFGraphicResource*)'
`DWFToolkit::DWFXMLSerializer::addAttribute(DWFCore::DWFString const&,
DWFCore::DWFString const&, DWFCore::DWFString const&)'
/usr/local/src/MgDev-2.2.4731/Server/src/Services/Kml/.libs/libMgServerKmlService.so:
`DWFCore::DWFZipFileDescriptor::zip(DWFCore::DWFString const&,
undefined reference to `WT_Gouraud_Point_Set::~WT_Gouraud_Point_Set()'
`DWFToolkit::DWFPackageWriter::DWFPackageWriter(DWFCore::DWFFile const&,
DWFCore::DWFString const&, DWFToolkit::DWFPackageVersionExtension*)'
undefined reference to `WT_Image::WT_Image(unsigned short, unsigned short,
WT_Image::WT_Image_Format, long, WT_Color_Map const*, long, unsigned char*,
WT_Logical_Point const&, WT_Logical_Point const&, char)'
DWFToolkit::DWFGlobalSection::provideResource(DWFToolkit::DWFResource*)'
DWFToolkit::DWFGlobalSection::provideImageResource(DWFToolkit::DWFImageResource*)'
`DWFToolkit::DWFPackageWriter::write(DWFCore::DWFString const&,
DWFCore::DWFString const&, DWFCore::DWFString const&, DWFCore::DWFString
DWFCore::DWFZipFileDescriptor::teFileMode)'
`DWFToolkit::DWFPropertyContainer::getAllPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
`DWFToolkit::DWFPropertyContainer::removeReferencedPropertyContainers(std::vector<DWFToolkit::DWFPropertyContainer*,
DWFToolkit::DWFGlobalSection::provideBookmark(DWFToolkit::DWFBookmark*)'
undefined reference to `DWFToolkit::DWFXMLSerializer::endElement()'
`DWFToolkit::DWFXMLSerializer::addCData(DWFCore::DWFString const&)'
DWFToolkit::DWFGlobalSection::provideName(char const*)'
`DWFCore::DWFBufferInputStream::DWFBufferInputStream(void const*, unsigned
long)'
collect2: ld returned 1 exit status
make[3]: *** [mgserver] Error 1
make[3]: Leaving directory `/usr/local/src/MgDev-2.2.4731/Server/src/Core'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/src/MgDev-2.2.4731/Server/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/MgDev-2.2.4731/Server'
make: *** [all-recursive] Error 1
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100418/b8def7e6/attachment.bin
