[mapguide-users] Passing SessionID to Fusion
Chris Claydon chris.claydon at autodesk.com
Mon Apr 19 10:37:41 EDT 2010
This issue should be resolved by the two submissions made against Fusion Trac ticket 361:
http://trac.osgeo.org/fusion/ticket/361
If you want to try to hack this into the 2.1 version, find the call to createSessionId() in fusionSF-compressed.js, and replace it with this piece of code:
var passedSessionId = Fusion.getQueryParam('Session');
if(passedSessionId == null || passedSessionId == ""){
    createSessionId();
}else{
    Fusion.sessionId = passedSessionId;
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GeorgesK
Sent: Saturday, April 17, 2010 12:39 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Passing SessionID to Fusion
Hello List,
I'm having trouble passing a previously created SessionID to Fusion by using
the "SESSION=" parameter. When doing so, Fusion still asks for username and
password.
In Internet Explorer 8, when I click cancel on the login prompt, the map is
displayed in the browser but using another (automatically created) session.
With Firefox (3.6.3), when I cancel, nothing is displayed.
I tried with the Ajax Viewer, and it works fine.
I read those threads (among many others) :
http://n2.nabble.com/fusion-user-authentication-in-MGOS-2-1-final-tp4271459p4271459.html
http://n2.nabble.com/Passing-username-and-password-into-url-with-fusion-tp3860654p3860654.html
I even tried Chris Claydon's solution here without success :
http://n2.nabble.com/Auto-authenticate-when-using-Fusion-Viewer-tp2120380p2123423.html
Has this problem been solved ?. I really would like to use Fusion instead of
the Ajax viewer, because of some of its features.
I am using MGOS 2.1 final.
Thanks in advance.
Georges
View this message in context: http://n2.nabble.com/Passing-SessionID-to-Fusion-tp4918427p4918427.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
