[mapguide-users] RE: current win-setup does not work
Jason Birch jason at jasonbirch.com
Mon Apr 19 12:43:35 EDT 2010
Should be enough.
You can turn on MSI logging in the registry:
<http://support.microsoft.com/kb/223300>Or you can use 7Zip to unzip the
installer, and then and run the MSI directly with command line options:
msiexec /i <name of msi file> /l*v log.txt
On 19 April 2010 03:50, stoff wrote:
> there are 17 Giga free ... should be enough. Or not???
> Is there another way to get an idea, what the problem could be? To start a
> debugging modus with params or something like that ...
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100419/a1fcafef/attachment.html
