[mapguide-users] RE: Major problems passing parameters using mapviewerphp
shepwaydistrictcouncil neil.thompson at shepway.gov.uk
Thu Apr 22 10:11:14 EDT 2010
Hi Tom
Just looked at your NNP interactive map and you've done exactly what we are trying to achieve right down to the search etc. Would you be in a position to share a little code or discuss directly?
Kind regards
Neil
Neil Thompson
Analyst/Programmer
Systems Development
Corporate Services
Shepway District Council, Folkestone, Kent.
Direct Tel:  01303 853340
Direct Fax: 01303 245978
E-Mail: neil.thompson at shepway.gov.uk  <mailto:neil.thompson at shepway.gov.uk>
Website: www.shepway.gov.uk <http://www.shepway.gov.uk/>
  _____
The contents and any attachments of this e-mail message are confidential and intended only for the named addressees.
If you have received it in error, please advise the sender immediately by return email and then delete it from your system.
Any unauthorised distribution, or copying of this transmission, or mis-use or wrongful disclosure of information contained in it, is strictly prohibited.
Shepway District Council cannot accept liability for any statements made which are clearly the sender's own and not expressly made on behalf of the council."
  _____
-----Original Message-----
From: Tom Chadwin [via OSGeo.org] [mailto:ml-node+4942845-132353366-224900 at n2.nabble.com]
Sent: 22 April 2010 14:59
To: Thompson, Neil
Subject: Re: Major problems passing parameters using mapviewerphp
Hi Neil
I have followed the instructions from the second link you quoted on several occasions. I find I usually make one or two errors, and it takes a while to get it working, but it absolutely does work. From memory, that example passes variables to the task frame, so you have to specify an initial script there, using Maestro or Studio, which handles the passed in variables, and then manipulates the map frame accordingly.
Is that the kind of thing you are trying to achieve?
Tom (also UK public sector, by the way)
  _____
View message @ http://osgeo-org.1803224.n2.nabble.com/Major-problems-passing-parameters-using-mapviewerphp-tp4941481p4942845.html
To unsubscribe from Major problems passing parameters using mapviewerphp, click  <http://osgeo-org.1803224.n2.nabble.com/subscriptions/Unsubscribe.jtp?code=bmVpbC50aG9tcHNvbkBzaGVwd2F5Lmdvdi51a3w0OTQxNDgxfC05ODY1NTk2Njk=> here.
system. Any unauthorised distribution, or copying of this transmission, or mis-use or wrongful disclosure of information
contained in it, is strictly prohibited. Shepway District Council cannot accept liability for any statements made which
This message has been scanned with email filtering and virus detection software by Shepway District Council
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Major-problems-passing-parameters-using-mapviewerphp-tp4941481p4942937.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100422/1aaa0faa/attachment.html
