[mapguide-users] Join Problem
Jason Birch jason at jasonbirch.com
Thu Apr 22 23:18:20 EDT 2010
Almost sounds like the resource is still there; didn't get deleted properly.
Is there any difference once you restart the service?
Can you access the repository with Maestro?  Does it allow you to delete the
original resource?  Does the validation tool point out any problems?
I don't know of anyone who has made a three-version jump.  It may be that
the authoring tools aren't backwards compatible with the feature source
schema that was used for 1.1, but it's hard to say.
Jason
On 22 April 2010 13:17, _Jon_ <jrizzo at langan.com> wrote:
> My migration saga continues.  I just migrated my site from 1.1 to 2.1.  I
> was
> able to migrate the data by exporting a package from 1.1 and loading it in
> 2.1.  While everything appears to have come over, some things are just not
> right.  I noticed that a join which was previously working properly (as a
> left outer join) is now operating as an inner join.  I opened up the
> feature
> source where the join was defined but the join appeared to be defined
> correctly.  Even though I did not make any changes, I tried saving the
> feature source but Studio wouldn't let me.  It gave the error: "Length
> cannot be less than zero.  Parameter name: length".  I changed a few
> settings and then changed them back, wondering what would happen.  It kept
> giving that error when I saved and eventually Studio crashed, throwing the
> same error as an unhandled exception.  When I went back in, I re-created
> the
> feature source & join.  It let me save the new feature source anywhere
> except in it's original (correct) location.  It kept giving me that error.
> So, I tried renaming the old f.s. and moving the new one into its place.
> Now, Studio crashes whenever I try to move this f.s. into place.  I tried
> deleting all layers that reference this f.s. but it did not fix the
> problem.
> I'm not quite sure what i can do next.  Help? (!)
> Jon
> http://osgeo-org.1803224.n2.nabble.com/Join-Problem-tp4946935p4946935.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100422/5422b909/attachment.html
