[mapguide-users] Modify Scale Ranges Of a Layers
Rajeev Singh rajeev at ipssi.com
Fri Apr 23 02:40:38 EDT 2010
Sriram,
In case you want to have a 'sticky' rememberance (sic) of last view of map
seen by user you could try something similar to what we did:
either at cookie level (or if you ask user to login, then login id) remember
the center and extent - Using javascript you can record this at the back end
whenever view/center is changed. (In our case we created toolbar action).
Then when the session is created the first time, get the information from
cookie and/or login id set the initial center and extent - the best place we
found was in ajaxmappane.templ
hope this helps.
thx
Rajeev K. Singh
IntelliPlanner Software Systems, Inc.
West Windsor, NJ (USA) / New Delhi (India)
+1.609.945.4927 (o) / +1.203.558.3224 (c)
+91.11.4672 6635(o) / +91.995 841 1064(c)
This mail contains proprietary and confidential information.
Please destroy it if you received it by mistake and notify the sender.
  -----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Jason Birch
  Sent: 23 April 2010 02:13
  To: MapGuide Users Mail List
  Subject: Re: [mapguide-users] Modify Scale Ranges Of a Layers
  The Session repository only stores resources for as long as the session
exists.  You will need to persist the layer definition somewhere in the
Library repository, and then figure out how to retrieve it next time the
user accesses your application.  Be aware that the anonymous user is not
permitted to write to the Library repository, so your app will need to
authenticate as a different user to do this.
  Jason
  On 22 April 2010 22:51, SriRam007 wrote:
    I want to keep permanently the modified scale ranges of a layers.
    I already have done By modifing the XML file of Layerdefinition for
changing
    the scale dynamically.
    And it is working fine also. But it exists till the session end. I want
to
    keep it permanently.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100423/b6c1d627/attachment.html
