[mapguide-users] Re: Trouble getting started
Maxi Wu maxi0361 at hotmail.com
Wed Apr 28 02:47:44 EDT 2010
Thank you for the trouble-shooting advice!
I tried it and the result is:
Loaded Configuration File  C:\Program Files\OSGeo\MapGuide\Web\Php\php.ini
and below that there are some load stuff maybe, MapGuideApi only got a name
with no more detail on it.
libxml
libXML support  active
libXML Version  2.6.26
libXML streams  enabled
MapGuideApi
mbstring
Multibyte Support  enabled
Multibyte string engine  libmbfl
Multibyte (japanese) regex support  enabled
Multibyte regex (oniguruma) version  4.4.4
Multibyte regex (oniguruma) backtrack check  On
Does this means settings are okay?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trouble-getting-started-tp4209353p4972967.html
