[mapguide-users] Re: Trouble getting started
Rohit Razdan rrrazdan at gmail.com
Thu Apr 29 04:25:59 EDT 2010
It is interesting to note that there are no modules loaded from
mapguide, in your module list. You should have the following plus the
FDO modules in the server/bin directory  and they should be loaded and
should show in your modules list. The mgserver service is running but
I have no clue why mapguide hasnt loaded these modules. A corrupt
install maybe??? Have you tried reinstalling. If not you can try doing
that or wait for people more experienced with the code base to respond
with a solution. You can also check if you have a lock file, it would
be hidden, I think. Also before running mgserver from the command line
did you stop the service, and make sure that mgserver.exe wasn't
running? If not, do that and post the output.
Regards
Rohit
Modules in server/bin/
20-09-2008  04:19         1,007,616 gd.dll
20-09-2008  04:16           884,736 libdb45.dll
20-09-2008  04:22         1,462,272 libdbxml23.dll
20-09-2008  04:24           602,112 MgFoundation.dll
20-09-2008  04:25         1,396,736 MgGeometry.dll
20-09-2008  04:24           122,880 MgGwsCommon.dll
20-09-2008  04:25           413,696 MgGwsQueryEngine.dll
20-09-2008  04:24            33,792 MgGwsResource.dll
20-09-2008  04:26           802,816 MgMapGuideCommon.dll
20-09-2008  04:24           282,624 MgMdfModel.dll
20-09-2008  04:25           430,080 MgMdfParser.dll
20-09-2008  04:26           516,096 MgPlatformBase.dll
20-09-2008  04:27         1,859,584 MgRenderers.dll
20-09-2008  04:28           249,856 mgserver.exe
20-09-2008  04:27           290,816 MgServerAdminService.dll
20-09-2008  04:26            81,920 MgServerBase.dll
20-09-2008  04:26            65,536 MgServerCache.dll
20-09-2008  04:27           991,232 MgServerDrawingService.dll
20-09-2008  04:26         1,454,080 MgServerFeatureService.dll
20-09-2008  04:28           172,032 MgServerKmlService.dll
20-09-2008  04:26           823,296 MgServerManager.dll
20-09-2008  04:28           344,064 MgServerMappingService.dll
20-09-2008  04:28           204,800 MgServerRenderingService.dll
20-09-2008  04:27         2,199,552 MgServerResourceService.dll
20-09-2008  04:27           282,624 MgServerSiteService.dll
20-09-2008  04:25            12,288 MgServerThread.dll
20-09-2008  04:27           143,360 MgServerTileService.dll
20-09-2008  04:27           573,440 MgStylization.dll
20-09-2008  04:29         1,802,240 MgUnitTesting.dll
20-09-2008  04:23           233,472 proj.dll
17-04-2010  16:53            26,285 serverconfig.ini
20-09-2008  04:17         1,892,352 xerces-c_2_7.dll
20-09-2008  04:20         2,580,480 xqilla10.dll
2010/4/29 =A4=A3=B7Q=AA=F8=A4j =B0=A8=B4=B5 <maxi0361 at hotmail.com>:
> Dear Rohit,
> Here they are, my system info(s).
> thank you for helping me.
>> Date: Wed, 28 Apr 2010 16:27:54 +0530
>> Subject: Re: [mapguide-users] Re: Trouble getting started
>> From: rrrazdan at gmail.com
>> To: mapguide-users at lists.osgeo.org
>> Hey Maxi,
>> Can you reboot, wait for a while for the delayed services to start,
>> and then run msinfo32.exe? You can either attach the saved .nfo file
>> or if you have privacy/other concerns, export software
>> environment//environment variables, software environment//Running
>> Tasks, software environment//Services, software environment//Loaded
>> Modules into text files and attach them, to your reply.
>> Regards
>> Rohit
>> On Wed, Apr 28, 2010 at 3:12 PM, Jackie Ng <jumpinjackie at gmail.com> wrot=
e:
>> > Maybe there's a stray mgserver.exe process running? Other than that I
>> > have no
>> > idea.
>> > - Jackie
>> > View this message in context:
>> > http://osgeo-org.1803224.n2.nabble.com/Trouble-getting-started-tp42093=
53p4973566.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Hotmail =ABH=BDc=B1=C4=A5=CE=B7L=B3n=B8=EA=B0T=A6w=A5=FE=A7=DE=B3N =B2{=
=A6b=B4N=A8=CF=A5=CE
