[mapguide-users] Setting / changing the initial Administrator password
Jason Birch jason at jasonbirch.com
Fri Apr 30 03:25:07 EDT 2010
The server admin has a password change function. Change at least the
admin password, and preferably the author password too.
There is a security white paper somewhere on the Autodesk site that
outlines some other important changes you should make before going
into production, such as disabling authoring through your standard
mapagent, etc...
On 2010-04-30, shepwaydistrictcouncil <neil.thompson at shepway.gov.uk> wrote:
> Hi all
> Although I've been involved with every aspect of tailoring MGOS through the
> phpviewer files to suit our needs I was not involved in the actual install
> as it was done via the MG Enterprise 2010 CD.
> We now want to move this to it's own server to prepare for public access and
> I'll be setting everything up from scratch using the downloads on your MG OS
> site but I'm a little concerned about the generic Administrator password.
> Am I able to amend this as part of the install process, or is there a way to
> modify it down the line after install?
> Additionally, as at present we've had Maestro and MG OS Server all on the
> same pc am I right that the following is how we would set it up:
> server : Apache2.2, PHP5, MGOS Server, MGOS Web Extensions
> developers pc : Maestro
> Many thanks for your help guys
> http://osgeo-org.1803224.n2.nabble.com/Setting-changing-the-initial-Administrator-password-tp4984284p4984284.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
