[mapguide-users] Re: selection problem using in mapguide using oracle10g
Zac Spitzer zac.spitzer at gmail.com
Mon Aug 9 03:45:01 EDT 2010
Also, with regards to number, try setting the scale/precision to 0
which maps to FDO int32, otherwise king oracle assumes an FDO decimal type
z
On 9 August 2010 17:43, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> you can safely ignore the 0.1.1.0 version number stuff
> but you could try a more recent version of the king oracle provider
> which you can download from here:
> http://www.sl-king.com/fdooracle/download/download.html
> just make sure you download the correct version for your mapguide server version
> z
> On 9 August 2010 17:39, ram282 <ram282 at gmail.com> wrote:
>> Can any one suggst some solution for this problem ?
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/selection-problem-using-in-mapguide-using-oracle10g-tp5379608p5388087.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
