[mapguide-users] Window Selection (Ajax) as ENVELOPE or INTERESECTS Confusion
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Mon Aug 9 11:44:30 EDT 2010
All,
We have an observation that doing a "Window Select" in MapGuide 2.1 (AJAX
viewer) queries on the feature bounding boxes and not the feature geometry
for Oracle (KingOra) connections.  The following is my understanding and if
anyone can confirm/replicate or advise that would be much appreciated.
Briefly:
Within "ajaxmappane.templ" there is a function called
'QueryFeatureInfo(...)' that implements the MapGuide HTTP API call for
OPERATION=QUERYMAPFEATURES.  This is documented here:
http://trac.osgeo.org/mapguide/wiki/HttpApi/RenderingService#QueryMapFeatures2.1
The current (default) value for the SELECTIONVARIANT value is "INTERSECTS" -
in theory we can simply change this to one of the valid values:
http://trac.osgeo.org/mapguide/wiki/HttpApi/RenderingService#SelectionVariant1.0
But the implication is that the default value of INTERSECTS is what is
required for accurate selection (rather then ENVELOPEINTERSECTS).
However, selected objects in an Oracle-based layer visually are outwith the
selection rectangle.
Turning on logging in the KingOracle provider shows that the query sent to
the DB is the fast SDO_FILTER and not the accurate SDO_RELATE.
However, the place where SDO_FILTER is built into KingOra is very clearly in
the switch/case for FdoSpatialOperations_EnvelopeIntersects so this is how
the query is processed!
So, what is happening between INTERSECTS passed as a param to
QUERYMAPFEATURES and it being received/interpreted as ENVELOPEINTERSECTS in
KingOracle (other providers not checked)???
 Crispin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Window-Selection-Ajax-as-ENVELOPE-or-INTERESECTS-Confusion-tp5389467p5389467.html
