[mapguide-users] Error When Printing in Fusion
Wilson Herrera wherrera at pccadpanama.com
Wed Aug 18 16:10:32 EDT 2010
Good day,
i am working in  some development for the fusion platform with mapguide.
one part of the development is to create custom print layouts, for that i
tried to extend the native print widget but i have been experiencing this
problem.
i tried to pass parameters on a single page, with excelent results ( you can
see the result in the attached image capture.jpg). but when i try to "fuse"
it with the print widget i get the following exception
Warning: sprintf() [function.sprintf]: Too few arguments in C:\Program
Files\Autodesk\MapGuide\WebServerExtensions\www\fusion\widgets\Print\printablepage.php
on line 63
i am sure that i wont have to modify the php code, but then the problem
resides on my implementation ( filename: printablepage.templ attached to
this message), i dont know where the error is,  i have a very simple
implementation that works well, but the main difference is the use of div's
in this, while the first one, were just cells in a table ( can attach it if
you need it ).
can you help me please to discover what is the reason for this error? thanks
in advance.
dont hesitate to ask if you need adittional info.
Wilson
http://osgeo-org.1803224.n2.nabble.com/file/n5437688/Capture.JPG Capture.JPG
http://osgeo-org.1803224.n2.nabble.com/file/n5437688/printablepage.templ
printablepage.templ
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-When-Printing-in-Fusion-tp5437688p5437688.html
