[mapguide-users] MGOS 2.2 Beta and OpenLayers 2.7
Jason Birch jason at jasonbirch.com
Tue Aug 24 20:31:09 EDT 2010
Hmm.
I don't have direct experience with consuming MapGuide via WMS / OpenLayers,
but EPSG:900913 isn't an official code, and I doubt that it is directly
supported by CS-Map.  Have you tried one of the subsequent codes (EPSG:3785
or EPSG:3857) that indicate "google projection" (Web Mercator)?  I'm not
sure which of these is bundled in MG 2.2, but am pretty sure that at least
one of them made it.
I believe that OpenLayers also supports several native MapGuide layer types
apart from WMS.
Jason
On 24 August 2010 16:02, iceman-11  wrote:
> The problem arises when I try to publish a WMS layer and read it using
> OpenLayers 2.7.  GetCapabilities tells me the layer is available.  But when
> I try to access it via an OpenLayers.Layer.WMS "add layer" call, nothing is
> displayed.  The same OpenLayers code works with an MGOS 1.2 server.
> My data is in EPSG:900913.  With the CSMAP projection change to MGOS 2+
> from
> MGOS 1.2, I'm afraid I may have lost the ability to simply pass the data
> through to OpenLayers without reprojection.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100824/171b0b78/attachment.html
