[mapguide-users] RE: Mapguide 2.2 Performance issue
Dave Wilson dave.wilson at autodesk.com
Wed Aug 25 17:08:31 EDT 2010
You will need to provide a lot more detail than "it doesn't work" to get a useful response :)
What configuration are you using? .NET, APACHE etc..
Are you using Basic or Flexible Web Layouts? What kind of data/providers are you using?
Are you using raster imagery and if so what format?
Yes the 64 connection limit has been removed, but other components including the Berkeley database and physical disk I/O for example will limit the number of concurrent connections?
What is your hardware? How many CPUs/cores? Is everything running on the same box?
What are your users doing at the time things lock up?
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Devadoss, Bala (US)
Sent: Wednesday, August 25, 2010 3:02 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide 2.2 Performance issue
We just started testing 64 bit MGO 2.2 on windows 2008R2. When we load tested our site with 10 simultaneous users, the Mapguide service stops responding and we had to restart the service.
I thought MGO2.2 is fixed to handle around 500 connections at the same time compared to 64 connections in MGO2.1.
Please throw some ideas for the performance issue.
Thanks,
Bala
This email is for the use of the intended recipient(s) only. If you have received this email in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not keep, use, disclose, copy or distribute this email without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. The information contained in this communication may be confidential and may be subject to the attorney-client privilege. If you are the intended recipient and you do not wish to receive similar electronic messages from us in the future then please respond to the sender to this effect.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100825/ba4922bd/attachment.html
