[mapguide-users] Re: How to show images with features layer.
Jamo adam.jamison at portbris.com.au
Wed Aug 25 19:05:20 EDT 2010
You need the image name at least to be stored as a property against the
feature...
Then using maestro edit the featuresource and
add a new extension
select the feature you want to extend
give it a name
then add a calculated property
something like concaternate(concaternate(' file://someserver/someshare/
</img>')
Then the image itself should show in the standard properties panel.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-show-images-with-features-layer-tp5461036p5463510.html
