[mapguide-users] Mapguide Open Source 2.1 2811 Port issue
Devadoss, Bala (US) Bala.Devadoss at am.jll.com
Mon Aug 30 19:02:21 EDT 2010
We have windows 2003 server running Mapguide Open Source 2.1. I ran in to Port 2811 issue and Mapguide fails to restart when I try to the restart service .
The error message I am seeing in the error.log is
 Success: Server stopped.
<2010-08-30T16:17:33> 2128
 Error: Port 2811 is not available, please try using a different port.
<2010-08-30T16:17:34> 2128
I  found the process ID that is using this port using the Netstat command and it seems that I cannot find the Process in the task manager.
We ran in to this issue more than couple of times in last the two weeks and ended up rebooting the server every time to solve the issue.
Is there anyone in the user community who had experienced this before? Is there any other app that might be using this port?  What should I do to fix this issue without needing to reboot the server or at least point me to the right direction?
Hope I have included all the information needed, please let me know if you need more information.
Appreciate your help on this.
Thanks,
Bala
This email is for the use of the intended recipient(s) only. If you have received this email in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not keep, use, disclose, copy or distribute this email without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. The information contained in this communication may be confidential and may be subject to the attorney-client privilege. If you are the intended recipient and you do not wish to receive similar electronic messages from us in the future then please respond to the sender to this effect.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100830/44760a9b/attachment.html
