[mapguide-users] MG 2.2 problems
Achim H. akimh69 at googlemail.com
Fri Dec 3 02:20:38 EST 2010
Hello,
I am switched to MG 2.2 and got 2 problems.
I tried to load a large (7 GB) .ecw file from a different external server.
When I set an Alias, Maestro doesn't recognize it .
Is there an workaround to connect to external ecw files?
My second question would be, after opening the print page ( with the map,
legend, etc.) I clicked on a feature to select it.  But the section polygon
has some sort of offset. This occurs only after opening the last print page.
I recognized that also in 2.1.
May somebody have an idea?
-- THX in advance
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MG-2-2-problems-tp5798871p5798871.html
