[mapguide-users] MG 2.2 problems
Zac Spitzer zac.spitzer at gmail.com
Fri Dec 3 19:10:34 EST 2010
did you restart the server after adding the alias?
On Sat, Dec 4, 2010 at 12:17 AM, Trevor Wekel
<trevor_wekel at otxsystems.com> wrote:
> If you are using MapGuide 2.2 32 bit on 64 bit Windows, replacing the GDAL library might help with ECW.  Please see http://trac.osgeo.org/mapguide/ticket/1476 for information on swapping out the GDAL library.
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Achim H.
> Sent: December 3, 2010 12:21 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MG 2.2 problems
> Hello,
> I am switched to MG 2.2 and got 2 problems.
> I tried to load a large (7 GB) .ecw file from a different external server.
> When I set an Alias, Maestro doesn't recognize it .
> Is there an workaround to connect to external ecw files?
> My second question would be, after opening the print page ( with the map,
> legend, etc.) I clicked on a feature to select it.  But the section polygon
> has some sort of offset. This occurs only after opening the last print page.
> I recognized that also in 2.1.
> May somebody have an idea?
> -- THX in advance
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/MG-2-2-problems-tp5798871p5798871.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
