[mapguide-users] Re: Generate a pdf view of the current map
Steve G steve.golden at morganhill.ca.gov
Fri Dec 10 17:13:34 EST 2010
Has anyone else succedded in getting this to work properly.  I tried but
everytime I tried to generate the PDF I got a HTTP 404 error (Page cannot be
found).  I am using MGOS 2.2.
I followed the instructions
1.  Put fpdf.php in \www\fusion\layers\MapGuide\php
2.  Changed the php.ini file as instructed
3.  Saved the given code to mappdf.php in the folder  C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\widgets\Print
4. Replacing in Print.js the given openPrintable: function() with  showPdf:
function() .  I also changed "openPrintable" to "showPdf" on lines 74, 160,
and 163.
I am generating a preview from Maestro, not sure if that matters.
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-a-pdf-view-of-the-current-map-tp5264270p5824811.html
