[mapguide-users] DWF generation error
Ricard ricardgrau at ieci.es
Thu Dec 16 10:38:34 EST 2010
Hi all,
First of all, sorry because I get this error using Autodesk MapGuide
Enterprise, but maybe someone has the same problem using MGOS and can help
me.
Generating a DWF file using MapGuide 2011 Enterprise causes the following
exception:
Application name: iexplore.exe, version: 8.0.7600.16671
Module name: EPlotRenderer.dll, version: 11.0.0.86
Exception code: 0xc0000005
Error offset: 0x00056069
The code used for generating the DWF file is identical to the one use in the
example “MG Utility Map” (plot.aspx)
The exception is thrown by the viewer installed as part of “Autodesk Design
Review”  ver . 11.0.0.86.
The exception occurs only when there are symbols on the map (represented by
png images)
However works perfectly when there are only lines on the generated map.
Thanks in advance
View this message in context: http://osgeo-org.1803224.n2.nabble.com/DWF-generation-error-tp5842369p5842369.html
