[mapguide-users] Re: Generate a pdf view of the current map
    Steve G
    steve.golden at morganhill.ca.gov
    Thu Dec 16 16:41:59 EST 2010
I didn't need luck, just your help!!!  Your changes worked.  Just to note:
mappdf.php
118     $tempMapImgPath .= $ImageType.$sessionId.time().$ImageFormat;   //
(dot before equal) on saveImage function
Should be at line 128
Also, you need to have a "fonts" folder in the same directory as fpdf.php
file (typical is C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\layers\MapGuide\php)
The resulting pdf image isn't the best quality, so I'll have to figure out
some additional tweaks...(anyone care to share?), but pdf creation at least
is possible.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-a-pdf-view-of-the-current-map-tp5264270p5843624.html
