[mapguide-users] WMS Map Problem
Luis Paolini l_paolini at uol.com.br
Mon Feb 1 06:00:14 EST 2010
Hi folks,
        I'm using Mapguide to publish some DWG files that can be accessed
via WMS Requests.
        I have used AutocadMap3D 2009 to publish the DWGs into Mapguide and
after that I've checked that the DWF files created
were perfect.
       After that I used Maestro to enable WMS and configure WMS parameters.
        Finally, when I send a WMS request and get a map back I can see that
some map geometries were moved (offset) from their
original position.
       Do you have any ideas?
       PS: I tried that on Mapguide 2010 and in Mapguide Open Source and the
result is the same.
Regards,
Luis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100201/cd20e2b8/attachment.html
