[mapguide-users] Re: "Failed to read schema..." error with GDAL
magnoliazz hanane.elyazidi at gmail.com
Tue Feb 2 06:57:27 EST 2010
Hi Kenneth,
I'm using the latest release of Maestro and I'm having the same problem. I
get the same erro message, no log entries, no last exception to view, and
when I add the raster layer I get  a blank map. Is there a way to avoid this
problem, any file format that would make it easier to use raster?
View this message in context: http://n2.nabble.com/Failed-to-read-schema-error-with-GDAL-tp4164488p4500381.html
