[mapguide-users] Re: mapguide-users Digest, Vol 38, Issue 1
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 3 03:32:05 EST 2010
There is no detailed info, the only document is the user guide:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
Are you using the Maestro 2.0 RC1 ? If not, try it.
If yes, can you post the entire message (if there is more) ?
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-02-2010 12:35, hanane el yazidi wrote:
> I'm a MGOS novice. I'd like to add a raster (.tiff) with Maestro, so I
> added an alias pointing to the directory where the raster is located,
> then I added a dataconnection with the FDO Gdal provider, tested the
> connection, and it was good. But when I want to add the raster layer,
> I get this error: "/Failed to read schema from data source. The
> operation gave the error message: Value cannot be null. Parameter
> name: input"/.  What am I doing wrong? is there some detailed
> documentation about the use of raster data in maestro.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100203/1e9dba58/attachment.html
