[mapguide-users] Re: "Failed to read schema..." error with GDAL
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Wed Feb  3 03:35:26 EST 2010
Are the files resonable size (eg. less than 10mb) so you can send one to
me for testing?
Otherwise, please try this page:
http://localhost/mapguide/mapagent/index.html
Click on "Feature", then "Describe Schema".
Just fill out the ResourceId with the ResourceId of the raster item, and
click submit.
The username/password is what you would use to login to Maestro.
If you post the result of that operation somewhere, I will have a look,
and see if I can guess what the problem is.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-02-2010 12:56, magnoliazz wrote:
>   release of Maestro and I'm having the same problem. I
> get the same erro message, no log entries, no last exception to view, and
> when I add the raster layer I get  a blank map.
