[mapguide-users] Re: MapGuideApiPINVOKE
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 3 03:42:22 EST 2010
Not sure why Signer.exe fails, but are you sure you can run corflags.exe
and ildasm.exe from the command prompt?
Could you examine if the "InnerException" holds more info:
http://dotnetperls.com/typeinitializationexception
The fact that the error message mentions "MapGuideApiPINVOKE" makes me
think that it has loaded
the MapGuideDotNetApi.dll just fine, but something else is breaking.
Since "MapGuideApiPINVOKE" is used to invoke the binaries, I assumed
they were of the wrong type.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-02-2010 10:27, Gunter Becker wrote:
> Kenneth, thanks for your reply.
> No, I don't think so because I tested it on another Windows Server 2008 /
> 32Bit and it works well.
> Next thing I tried was to use your signed MapGuideDotNetAPI.dll you posted
> some days ago. This also doesn't work. And then I tried to sign the
> MapGuideDotNetAPI.dll by myself with the Signer.exe you mentioned in a
> former thread. I dit it directly on the server in the Visual Studio 2008
> Command Prompt and it fails with the following message:
> c:\Tmp\MaestroKey>Signer -k c:\tmp\MaestroKey\maestroapi.key -outdir
> c:\tmp\MaestroKey\Strong -a MapGuideDotNetApi.dll
> Execute of corflags.exe failed
> Execute of ildasm.exe /? failed
> An unexpected processing error did occur: System.NullReferenceException:
> Object reference not set to an instance
> Maybe it is an .NET issue? What else can I try?
> Thanks, Gunter
