[mapguide-users] FDO/SQL formating expressions
oshan icycool at inbox.com
Thu Feb 4 03:57:09 EST 2010
Hi I am wondering what are all possible expression I can use in with FDO
properties. For example in mapguide meastro formating the labels.
I have found out through the sample sheboygan that Contact() is one such
expression. And from this forum I found Translate() is also another one. I
tried using Substr(Propertyname,index) and this also worked! So is there a
place where I can find out what are all the expression I can use like that?
Right now I want to be able to split the label name by "," so there is no
such expression such as spilt by at least is there a expression to get the
position of a character?
Thanks heaps
View this message in context: http://n2.nabble.com/FDO-SQL-formating-expressions-tp4512311p4512311.html
