[mapguide-users] Re: Change map scale or get min and max scale from layer
Johannes Foell jfoell at uos.de
Tue Feb 9 07:38:40 EST 2010
I've solved the same problem to gain the ScaleRanges for Visability with the
given solution. Unfortunately, I need the current scale to set the Layer
shown in an outsourced Legend.
Is there a way to achieve the current scale? The method GetViewScale() gives
1.0 to me, too.
Thanks for help in advance.
Kind regards,
Johannes Foell
View this message in context: http://n2.nabble.com/Change-map-scale-or-get-min-and-max-scale-from-layer-tp1817851p4540806.html
