[mapguide-users] Studio Load Procedure and Maestro File add with Shapefile gets a 404 not found
Jason Birch jason at jasonbirch.com
Thu Feb 11 01:37:38 EST 2010
Anything in the system log, webserver log, or virus scan log on the server?
Anything odd about the filename?
Once the packaged data is loaded, are there any problems accessing the
schema description?
Red herrings, free for the asking :)
Jason
On 9 February 2010 13:53, Kori Maleski <kori.maleski at gmail.com> wrote:
> Has anybody encountered this scenario?
> Using either Maestro or Studio to load a Shapefile results in a 404 not
> found error.
> No issues with any other shapefiles with the same load procedure or Data
> resource setup from the exact same directory.
> I can package the data and load it in order to bypass.
> Stop/starting server has no effect.  There is caching enabled on
> shapefiles.  Is there possibly a lock?  Shapefile opens and geometry has
> been repaired in ArcMap, so I don't think it is data related.
> Cheers,
> Kori Maleski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100210/27caa823/attachment.html
