[mapguide-users] Out of memory issues. Help please??
Trevor Wekel trevor_wekel at otxsystems.com
Thu Feb 11 08:58:00 EST 2010
Zac is correct.  There have been a lot of memory leak fixes put into the latest releases of MapGuide and FDO.  In addition, one of the key features for MapGuide Open Source 2.2 is 64 bit support.  The larger memory space available to a 64 bit MapGuide Server will make any remaining memory leaks less critical from a stability perspective.
The MapGuide Open Source roadmap has been updated (thanks Tom!) with some additional information on the key features and timeline for the 2.2 release http://trac.osgeo.org/mapguide/roadmap
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: February 11, 2010 2:44 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Out of memory issues. Help please??
2.1 is definately more stable, there have been even more good fixes since
which are in the trunk for 2.2 which will hopefully be beta in march
upgrading the core server isn't that bad
are you using customised viewers?
whats your fdo providers talking to?
any gdql rasters?
On Thu, Feb 11, 2010 at 8:39 PM, JamesDudden
<jamesdudden at blueyonder.co.uk> wrote:
> Hi,
> I have been getting a lot of 'Out of memory' errors that have been causing
> Mapguide to crash as below:
> StackTrace:
>  - MgMappingUtil.StylizeLayers line 786 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
> Failed to stylize layer: Boundaries
> An unclassified exception occurred.
> <2010-02-10T12:03:41>           127.0.0.1       Administrator
>  Error: Failed to stylize layer: All OS
>        Out of memory.
>        bad allocation
> I am using MG 2.0.2 and have been told that a lot of 'memory leaks' have
> been fixed in 2.1 but upgrading seems like a massive task.
> What exactly are these 'memory leaks'?
> Will upgrading the server hardware i.e. better processor and more memory
> help at all or is it a wasted purchase?
> Are there any tweaks I can make to improve the situation or is upgrading my
> only option?
> Any help or advice is welcome
> Regards
> JD
> http://www.software-matters.co.uk Software Matters  -
> http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
> Database  and Software Solutions
> View this message in context: http://n2.nabble.com/Out-of-memory-issues-Help-please-tp4553622p4553622.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
